bizhub 600 c 6708
  • faisal jilani
    saad jilani
    • Sep 2008
    • 40
    bizhub 600 c 6708
    hi.i have biz hub 600 this machine code is coming c 6708 i reset but again is coming any beady no this problem.
  • ni311
    • May 2008
    • 658
    Code:
    C-6708*
    Causes:
    AGC adjustment level abnormality.
    • The light blocking cover at the read section and the lens cover are removed.
    • The connector of the CCD board (CCDB) is disconnected.
    • The power cable of the CCDB is unplugged.
    • The IC protector of the CCDB converter board is cut off.
    • The light volume of the exposure lamp is excessive.
    • The exposure lamp does not light up.
    Estimated abnormal parts:
    CCD board (CCDB)
    Exposure lamp (L1)
    Konica Minolta Error Codes - Explanations and Solutions
