c451 setup
  • art neumann
    c451 setup
    Our office has a c451 and prior to changing our email service the unit was set up to scan to email. Is there a simple list of the settings that the machine should be set at in order for this to work. The dealer we use doesn't have a qualified person available for this and it is now getting frustrating as we used it often. i have changed settings that I thought I was suposed to but now all we get is a server error.
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    I would contact a dealer with a qualified network tech.
    Parts: Its what your copier craves!
      • 30293
      email
      new smtp server
      new email address
      new password
      try with Authentication on and off
      admin email address
      • 8050
        • 88
        When you go into your email settings and enter your SMTP server is it by host name or IP address? When you're in NETWORK settings forward screen to DETAIL and you have a PING CONFIRMATION tool. Enter host name of your SMTP server and ping it. If your DNS is running okay the host name should be ok to enter, if you get back a ping failed try entering IP Address and test pinging it.
