Adding/Editing Favorites Setting in Printing Properties Bizhub C650
  • Nick_Sampson
    • Aug 2025
    Got one more question if anyone has some insight on this. If I open Printers/Faxes and go into our Bizhub's Printing Preferences I can create custom favorite settings that allow me to pick between how I want my documents to print. I have a custom setting that I created for 2 hole punch top, 3 hole punch left with different cover sheets based on what document I'm printing.
    When I open a document I'm trying to create a new Favorite Setting by selecting Print then picking our bizhub then going into the print properties that way and the Add/Edit are greyed out. I have given myself full permissions in the security tab and I still have no luck editing it through the document.
    If I log onto the Server that the printer has been installed to I can edit these options both through Print/Fax and by opening a document and editing it that way. It seems the issue I'm having is only related to making settings on a workstation, no matter where I do it on the Print Server i can.
    Am I overlooking an Active Directory or File Permission setting somewhere?
    Thanks for the help,
    Nick Sampson
  • Nick_Sampson
    Nick Sampson
    In case anybody runs into this question, you need to install the printer drivers locally even if you have the printer set up as a shared network printer on a server.
    Once I added the printer locally and added it to the TCP/IP port it's configured for I was able to make the changes via documents.
