hi guys need some help
  • copiers4africa
    • Jul 2009
    • 47
    b350 with abort code 0000999a
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    MFBS board, fax board,or memory board, per the service manual.
    • The copier guru
      Machine show abort code 0x0000999a when is printing PDF documents.
      [Solution]
      Problem is generated by software Foxit Reader.
      Please install Adobe Acrobat Reader.
      • PaperCut
        • Sep 2008
        • 21
        try this
        http://www.copytechnet.com/forums/ko...-help-pls.html
        • copiers4africa
          • Jul 2009
          • 47
          thank u u r right foxit is da problem...many thnx
          thank u for thew solution foxit reader is installed change to adobe problem gone.
          [Solution]
