Bizhub 350, network settings button inactive.
  • Hansoon
    • Sep 2007
    • 3402
    Rebuild machine was working when leaving the shop. IP-address modified and tested afterwards. Everything was fine.
    Customer now called that the IT guy could not set up the IP address cause the button "Network Settings" under admin2 is present but doesn't respond. Touching it doesn't show a reaction. All other buttons in the display under Admin2 except Network Settings are operative.
    What could have happened? Are there any soft switches the IT-guy might have fumbled with locking the Network Settings button out?
    Hans
  • emujo
    • Jun 2009
    • 3009
    Turn off TCP settings, cycle power, turn TCP setting back on, cycle power again. Seen this happen a few times and this has always corrected it. EMujo
    • Hansoon
      • Sep 2007
      • 3402
      Don't get it, from where?
      Hans
      • Hansoon
        • Sep 2007
        • 3402
        Anybody having please for me a list with soft switch settings? I think that IT-Bloke turned the print function off cause I cannot even print the machine report.
        Hans
        • apache_cat
          I.T. Tech
          • Jul 2009
          • 81
          I am pretty sure on these there is a network on/off switch that is seperate from the network settings. It is easy to find just cant remember where. Just browse the menus it is a straight network on/off switch.
          • Hansoon
            • Sep 2007
            • 3402
            Managed to solve the problem by doing a Total Clear in the Initial Mode.
            Thanks.
            (But still interested in that softswitch settings list)
            Hans
