Minolta Di 550 SC23-03
  • alphatech
    Can't seem to find out what this code means. It happens intermittently. Can anyone tell me?
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 219
    sc 23-03
    PROBLEM:
    At times an SC23-03 can be displayed.
    CAUSE:
    When the machine is operating in a high temperature, high humidity environment it is possible that M2 does not
    rotate at the proper timing.
    SOLUTION:
    The circuit board of M2 has been redesigned to prevent the code from being displayed.
    i copied this from database so here is the thing old part number for this part was
    4024-202501 the new one is 4024-2025-02 it gets rid of the code. it actually works i have had the problem myself. anyways good luck
    • mikeena
      • Mar 2007
      • 219
      so just curious if you were able to fix the problem
      • xpress
        • Jun 2008
        • 63
        sc23-03
        I have gotten this code a few times on our 650. I dont know about the first time, but this most recent time it was caused by the toner recycling tube not being installed properly in the down / open position. That caused a backup of toner which apparently resulted in the mt-2? motor slowing or not turning at all....
        When I tried to lower the corona engagement lever it wouldnt drop so I had to remove the large gear on the toner recycler, then rotate the auger by hand to discharge the backup of toner in the tube. After that, I reinstalled the large gear, closed the doors and power cycled the machine. That cleared the code , it ran for awhile clearing toner I suppose. After that I removed the dv unit, vacuumed the toner from under it, and am now trying to clean up the copies.
