Bizhub C350 Scanning problem
  • julesqb
    I am trying to find out how to have a multiple page document scan into my server as one file. Right now it scans and makes a file for each page. I have looked through the book and can't find any instructions for this. Any help would be appreciated.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    What format are you trying to scan in? Jpeg and bitmap do not support miltipage files PDF does.
    Now into Ip TV KODI Boxes
    • julesqb
      I am scanning to PDF format to my server.
      • pepper38_cnd
        • Aug 2005
        • 1075
        Do you have the standard controler or the Fiery (IC-401)?
        • julesqb
          Bizhub C350 scanning
          I have no idea, where would I look to find that info? Is it a seperate component? Is it in the books? I just started with this copier and no one seems to know anything about it, so I am trying to figure it out.
          • B0265
            • Jan 2007
            • 718
            You need to install a engine HDD (HD-501). I'm not sure if they a still available anywhere.
            • pepper38_cnd
              • Aug 2005
              • 1075
              Here is a link to dowload the standard controller Operators guide. Your answers will be in section 8. Check out page 8-17 and see if this helps. I believe the Hard Drive was standard in machines sold in North America so you should not need to add it unless it's been removed.
              Hightail Spaces lets you send unlimited files, of any size, to anyone. Collaborate with your team and evolve your work.
              • julesqb
                HD-501
                I was looking at some other posts and several have said that using a standard 40-80gb notebook harddrive and then just do the physical format first and then the logical. Do you know anything about that.
                • B0265
                  • Jan 2007
                  • 718
                  You can probably use a standard notebook HDD, the problem is to find the mounting parts.
                  • lanierboy
                    • 149
                    if you are scanning via email check that a/ there is no linit set in the email server settings and that b/ binary division is turned off.
                    to access this info log onto machine via web browser and log in as admin
                    select network and email tx.
                    • emujo
                      • Jun 2009
                      • 3009
                      Log into Page Scope as User or Admin. Go to Scan Tab, Select Program, New Registration, Select scan method (SMB, Email etc). The program field gives you the option of choosing Multi-Page PDF. Input the needed info and save. When you choose scan from the MFP LCD, go into the program tab and you should see your new 1 touch there. EMujo
                      • popcornpuppy
                        • 29
                        when you create the one touch button in utility mode i think you have an option to set the default as 1 page PDF or multiple page PDF
                        • PaperCut
                          • Sep 2008
                          • 21
                          on the control panel , go to scan, settings, go to PDF, on the right side on the screen select MILT PDF
                          • newbie
                            • 62
                            Not on the c350. On the c450 and others you do. You have to choose the scan file separation option in order for it to do multi page scanning. Since the c350 was one of the original new biz hub color units there are a few things missing but it seemed to be corrected with the release of the c450. Since we still have over 100 c350's in the field Ive learned to deal with it and find ways to make it work.
