DI2510 network problem
  • wwandrei
    • 40
    Hello. I have some DI 2510 equipaments to a client of mine and i have some problems with some of them. Randomly during the day it starts printing slow like one page and 10 seconds no matter if is pdf or doc or other file type and will start work corectly only if it`s turned off, unplug power cable, turn on few times with cable unpluged, then plug cabble and turn on the copier. I also noticed that i am not able to connect via web browser to copiers IP because is responding so slow. If i ping the machine it responds well ... it is a big company with a big network, and their network is tested and works fine, I also have this problem to other company ... unable to connect to web interface, slow printing etc ... also if i connect the copier with a notebook directly i can access it by web without a problem. I heard that it might be some incompatibility problems between copier NIC and some switches with management or routers ... did anyone had this problem? Thank you.
