Please I Wanna Solution For My Copier Problem !
  • sacha
    • Aug 2025
    hello,
    i have a trouble in my copier ( Konica minolta Di 550 ) .. Well, the copies from my copier right now are nice and clear, but in the margins the text is pale.
    this is how it looks :
    when i turn the devlopper , the problem solved , after a while the problem come back againe
    is that from the devlopper or the engine or another thing.
    Can Any One Help Please ?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    On that series of machines there is an issue with the smallest gear on the dv box getting stripped. It may be hard to tell, but look close. Some of them will turn if the box is empty , but not under a load. If it is stripped, change the gears it comes in contact also and the bushings behind the gears.
    • sacha
      More Details About the problem
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        First of all, I am sorry I read the first post wrong and thought it was for a 5510.
        When you say it is not turning, have you marked the gear to see if it is not moving or if it is something inside the toner hopper.
        If I remember correct, There was an issue with the auger in the hopper breaking on one end and not turning.
        The info you are giving is great with the pics, I hope if I am no help some one else will post.
        • Hansoon
          • Sep 2007
          • 3389
          Well one thing is sure, Sascha still might have to learn a little more about copiers but he knows how to use computers and his Graphical Presentations are awesome.
          Hans
          • time2fly
            • Jul 2008
            • 134
            amen Hansoon. Replace the developer, the whole unit. It's better that way.
            • pepper38_cnd
              Field Service Manager
              • Aug 2005
              • 1075
              It is more than likely that the doctor blade area of the Dev Assy is contaminated with paper fluff not allowing the dev to flow in that area. Tare off a piece of copy paper and run it back and forth under the doctor blade. If this appears to solve your problem, dump the dev and vacuum the unit throughly ( you may want to remove the sensor before vacuuming ) then replace developer.
              Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
              Now into Ip TV KODI Boxes
              • JustManuals
                • Jan 2006
                • 9838
                Hans
                And he's certainly not shy about using someone else's bandwidth to post his pictures either.
                • Hansoon
                  • Sep 2007
                  • 3389
                  In addition the the Pepper's advise I think its worth to give the laser path (slit glass) a look. Would also be interesting to know how the image looks on the drum when crash stopped. Beside of that, somehow hard to imagine that, quote: "turning the developer" will improve the copy quality for a short period. Could it be that there's developer missing? Perhaps after previous "cleaning" attempts?
                  Off Topic:
                  Never realized that could be an issue. Always thought using pictures was a good idea to make things clear.
                  If this is undesired by the forum owner / moderators let them please speak out.
                  Hans
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Off Topic:
                    Hans
                    I already did.
                    • Hansoon
                      • Sep 2007
                      • 3389
                      I already did.
                      Hans
