Konica 7033 error 52-2
  • ezduzit
    Howdy! Need help with konica 7033. Looking for description and suggestions for error 52-2. Any help would be great
  • copyguy5
    DESCRIPTION:
    F52-2 prior to the completion of warm-up. SOLUTION ID:
    99,245
    SOLUTION:
    CAUSE: CN33-B9 (control signal for the conveyance suction fan, FM4), located on the printer
    driver board (PRDB), is not properly seated.
    SOLUTION: To check the operation of the conveyance suction fan, perform the following:
    1. Power the copier OFF (using sub power switch, SW2).
    2. Access the 47 multimode (power the copier ON, while pressing the 4 and 7 keys), ouput code
    42, press P-04-P.
    3. Using a voltmeter (200V DC range), check the conveyance suction motor drive signal at
    CN33-B9 on the PRDB, which is the 24V DC power origination point for actuation of the
    conveyance suction fan. A reading of 24V DC should be measured when the fan is in the ON
    mode and 0V DC should be measured when the fan is in the OFF mode.
    4. If 0V DC is measured with the conveyance suction fan in the ON mode, power the copier OFF
    (using sub power switch, SW2 and main power switch, SW1).
    5. Remove CN33 from the PRDB.
    6. Ensure that all the pins for CN33 on the PRDB are straight and properly aligned. Then inspect
    CN33 on the wiring harness. Ensure that all the wires are properly attached to the connector.
    7. Reseat CN33 on the PRDB.
    8. If 24V DC is measured for a second and then it goes to 0V, check the fan connector (CN57).
    This is what I found. Hope it helps
    Copyguy5
    • ezduzit
      thank you sir!
