Curly Output on C6501
  • resolute
    • 28
    I have excessive curl on the output (from all trays) from all papers. There is quite a bit of curl as it lands in the output tray. Really bad on 12 x 18 Cardstocks that are shortgrain.
    Does anyone know if I should adjust an upper or lower fusing temperature to affect the curl... or other suggestion?
  • armaddon
    • Sep 2009
    • 11
    Honest-to-goodness best suggestion would be to check for humidity... Had a very similar experience with one of our print shop customers. Turned out they were storing ALL their paper out in their cold musty warehouse until they needed it for a job, which would of course end up curling and jamming like crazy.
    • random
      If you have a RU you can turn the curl reform either up or down to remove the curl.
      • Setright
        FSS / SPM
        • Nov 2008
        • 247
        Yeah, what they said, both very good suggestions.
