driver installation in mac operating system
  • thuo
    • 155
    i need assistance in installation of biz hub c353 in mac operating environment.
    thanks
  • jneezy2008
    Software/IT
    • Mar 2009
    • 72
    The snozberries taste like snozberries!!
    • mascan42
      • Oct 2008
      • 484
      Originally posted by jneezy2008
      Verify AppleTalk is set to ON on the bizhub. If it's set to OFF just set it to ON and click OK.
      You could even set Bonjour to ON then you could install the printer using either AppleTalk or Bonjour.
      Does anyone still use AppleTalk? It's become so unpopular that Apple doesn't even support it in the latest OS.
      • apache_cat
        I.T. Tech
        • Jul 2009
        • 81
        Line Daemon for me.
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          Well if you using OS 9 appletalk is what you need the OS will find your machine in on time, and then run the PPD file for your machine, you can use the Macs systems generic driver it will print but some feature will not be available. Most G3 Macs still work on OS9 its a machine that run till it dies.
