Cf9001 trouble counter
+ More Options
Posts
  • BUSHWACKER
    • Aug 2008
    • 25
    Greetings, the error code c3f90 seems to be linked to the error counter that reads tbase - any clues what to look for - cannot find any info in the manual
    Thanx
  • mrwho
    Major Asshole!
    • 4299
    Try these:
    DESCRIPTION: C3F90 displayed during warm-up.
    CAUSE: The PC drum is not properly installed.
    SOLUTION: Ensure that the PC drum is inserted fully into the machine. It may be necessary to rotate the drum slightly clockwise until it fully slides into place. To reset the C3F90 error message, perform the following:
    1. Move the Transfer Unit handle (M4) to the right to lock it into place.
    2. Remove the cover over the Tech. Rep Setting Switches Board.
    3. Press switch S24 to reset the message.
    4. Replace the plastic cover over the Tech. Rep Setting Switches Board.
    C3F90 error message.
    CAUSE: Transfer Unit handle (M4) is not locked into position when making a copy or printing. This may happen while a technician is servicing the 7823 with the door interlocks cheated.
    SOLUTION: To reset the C3F90 error message, perform the following:
    Mascan42
    Ibid
    • BUSHWACKER
      • Aug 2008
      • 25
      Thanx
      Great stuff thanx - no one over here in South Africa was able to assist
      • mrwho
        Major Asshole!
        • 4299
        Well, that's an old machine. Good copy quality but a pain to maintain.
        Did that solve your problem?
        I'd like to go down there someday, but the money is short.
        Mascan42
        Ibid
        • BUSHWACKER
          • Aug 2008
          • 25
          Fixed
          Great all functioning it did seem as though the m4 lever was not locating properly.
          Which neck of the woods are you from
          Regards
          Bushwacker
          • mrwho
            Major Asshole!
            • 4299
            Europe. Just find the westernmost point in mainland Europe and I'll be about 180Km from there
            I know, I could tell you right away, but what the heck, I'm bored!
            Glad I could be of assistance.
            Mascan42
            Ibid
