Bizhub 250 need help to reset C2557 code
  • allbrandsrepair
    • Aug 2025
    My customer tried to replace the drum on his KM Bizhub 250 himself. He did replace the drum, but not knowing what he was doing, he dumped the developer and replace it with toner. The code C2557 came up.
    After I found out what he had done, I removed the toner and replaced it with developer, reset drum and maintenance counters, ran F8, and restarted the machine. The code came back up again.
    I then installed a brand new developer unit, using the new developer I had just replaced into the old developer unit, reset drum and maintenance counters, ran F8 again. The machine came into ready, ran (1) copy, jamed on fuser entry and C2557 fired again. I then reset the switch in the back (right hand side), reset the switch on the main board, reset drum and maintenance counters, ran F8 again. The machine came into ready, ran (1) copy, jamed on fuser entry and C2557 fired again.
    Any assistance or recommendations would be appreciated.
  • Si@danwood
    • Mar 2008
    • 154
    Go into service mode and adjust ATDC value to 85,this should get you working again
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      At this point, I would put another drum in.
      • J_Lee
        • Oct 2008
        • 111
        I'm having this problem also.. And I usually work on sharp. I relaced the drum and changed the developer/starter.. changed th ATDC to 85 and still this code??
        • racosta
          • 53
          J_Lee you might need to pelace the ATDC sensor under your Dev unit.
          • Chip Resets SA
            • Sep 2010
            • 46
            Play with your ATDC value. If 85 doesn't work, put it up to 95 and so on. It is a guessing game but you will find it soon enough.
            • J_Lee
              • Oct 2008
              • 111
              How do you reset the developer count specifically.. Im used to Sharp so you'll have to excuse me.
              • Konica_jr
                • Aug 2010
                • 25
                from infohub :
                Select Tech. Rep. Mode --> Counter --> Special Parts Counter --> PC Life.
                2. Press the Clear Key to clear the counter value.
                3. Turn OFF the main power switch.
                4. Open the Right Door.
                5. Remove the IU.
                6. Remove four screws (silver) and disassemble the Photo Conductor Unit and the Developing Unit.
                7. Replace the Photo Conductor Unit.
                8. Remove three screws and the Developer Scattering Prevention Plate.
                9. Remove the Toner Supply Port.
                10. Remove the Developer.
                11. Set the developer while rotating the gear in the direction of the arrow.
                12. Reinstall the Toner Supply Port.
                13. Using three screws, secure the Developer Scattering Prevention Plate.
                14. Install the four screws to secure the Photo Conductor Unit and Developing Unit.
                15. Install the IU in the copier.
                16. Turn ON the main power switch.
                17. Select Tech. Rep. Mode --> Function --> F8 and press the Start Key.
                " French do it better " ^^
                • Konica_jr
                  • Aug 2010
                  • 25
                  Try another developer, developer can only be calibrate one time.
                  • fixthecopier
                    ALIEN OVERLORD
                    • 4713
                    If you tried to run it with out resetting the count you are screwed. Change the developer again, but first clear the counters.
