After the TCR adjustment the result was not good (NG) and started throwing C 2803
(TCR output abnormality. When the output ripple voltage of the TCR sensor (TCRS) is less than 0.5 V)..
Tried to reset (main Switch and utility) copier resets and goes back to the code c2803
Is there another step to replaced developer?
(Throw old, replace with new, ran TRC adjustment)????
Any help on this problem?
