Konica Minolta BH500 squeaks
  • krm
    • Aug 2009
    • 233
    With the right door opened and switch cheated, there is no noise, the fuser, clutches, drum/developer all drive with no noise. Only when the door is closed is there squeaks. I replaced the duplexor clutches and the noise continues. Any suggestions?
  • mo0651
    • 1054
    There is a little white gear on the lower right hand inside of jam access door. There is a bearing in one of the gears. That is the cause of your squeak this time. Probably will have to replace it. Not much luck with clean and lube.
    • HuronMan
      • Jul 2009
      • 68
      Another thing to check is ADU drive assy. Check out pg. 74(pdf 107) of the field manual for a good pic. I've been finding the input gear is the problem. Try going into state confirmation, load check, code 21-1, open door, cheat switch, hit start and use your thumb to press on the gear that meshes with the spring loaded duplexer gear. Squeals like a pig. Lil bit of plas-gard should do it.
      • krm
        • Aug 2009
        • 233
        thanks for the input, I have not returned to machine yet. When you say gear behind access door, do you mean inside right side door? I see the spring loaded gear assembly, is the squeaker one of these gears?
        Thank you.
        • mo0651
          • 1054
          That's the ones. Good luck!
