I have toner collecting on the outer edge of the belt cleaning blade. It collects on the first two inches in from the front side and leaves streaks. The rest of the blade is fine and cleans the belt properly. I have to clean 2 or 3 times per 100k pm cycle and sometimes replace blade too.Toner is not packing or backing up in the cleaning unit, which I have replaced. I have updated the Eprom with the fan modification for the heat issue. Replaced the transfer guide rollers and belt support shaft, belt driving roller and bearings,blade tension springs. Any ideas what might cause this?
Konica 8050 color copier/printer
