EP5000 repair
  • eevansx
    EP5000 repair
    I am currently repairing a EP5000 and have an issue with startup. After clearing all trouble codes, I have a problem getting a sample coy for evaluation due to errors of Lower Left Door and Duplexer drawer open.
    I have connected the unit and ensured the sensors are closed. I have also tried disconnected the PF5 and receive the same error.
    I have a manual set but have failed to find rhe override to service the main unit.
    Any references to manual pages or "tricks" to bypass the probem and test/repair the main unit would be most appreciated.
    Evan
  • perdana
    • Jan 2008
    • 62
    EP 5000
    To Overide that, you must disconnect connector on lower left door (in rear)
    • Hansoon
      • Sep 2007
      • 3376
      I remotely recall there was something with the waste toner box not sitting right when this happens.
      Hans
      • eevansx
        prolm solved
        perdana, thanks!, you wer exactly right.
        Why shoving a cigarette butt into the photointerrupter didn't work I'll never know.
        Thank you, als to Hansoon... it is jut this sort of esoteric knowledge that makes us look like heroes to our clents!!
        Evan Evans
