Bizhub C500 jam error msg
  • copyfax20
    • Oct 2009
    • 19
    Hi, I work with Konica Minolta Bizhub C500, but when power on in display a message to paper jam in fuser section (9) is present. I check in fuser and not paper jam is present. How can i resolved a problem?
  • Si@danwood
    • Mar 2008
    • 154
    The jam code would be helpfull but i would check the connector to the exit switch located o the fusing unit they get pulled slightly appear to be connected but actually are not!Also a blown icp on the adu pwb can cause similiar fault(ICP2 i think)..si
    • agudmove
      • Jun 2009
      • 70
      I work on Develop machines, had the same problem recently on Ineo 500 (same as Bizhub 500), faulty PS3, exit sensor was the problem.
