Bizhub C203/FS519 - Mailmerge-stapling
  • Techno Sid
    When trying to do a mailmerge from MS Word & the address list is in Excel, the whole set is stapled as one, instead of individual sets. I beleive that this is an issue within Word & a macro needs to be embedded in the document. Customer is using Word 2000 & 2003. Does anyone have a copy of the macro, or know where to get it from?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    This is a mail merge issue. Do a search on the Microshaft website and you should see several solutions depending on which version you are using. I have also seen a post on a website on how to write the macro as well. Just google mail merge and you should be able to find it.
    Here is one such site.
    MSWord Mail Merge
    • Kbros
      I hope this helps in mail merge
      Applying printer finishing options in a Microsoft Word Mail Merge
      Sub Mail_Merge_Print()
      ' Mail_Merge_Print Macro
      ' Macro written 05/08/00 by Len Hoyt
      lhoyt@ikon.com
      Application.ScreenUpdating = False
      Rem Selection.HomeKey Unit:=wdStory
      Selection.Find.ClearFormatting
      With Selection.Find
      .Forward = True
      .Wrap = False
      .Format = False
      .MatchCase = False
      .MatchWholeWord = False
      .MatchWildcards = False
      .MatchSoundsLike = False
      .MatchAllWordForms = False
      End With
      Do
      Selection.Extend
      Selection.Find.Execute FindText:="^b"
      If Selection.Find.Found = False Then Exit Do
      Selection.MoveUp Unit:=wdLine, Count:=1, Extend:=wdExtend
      Application.PrintOut Range:=wdPrintSelection, Background:=False
      Selection.MoveDown Unit:=wdLine, Count:=2, Extend:=False
      Loop
      End Sub
      position.
      • 4evertech
        Re: I hope this helps in mail merge
        This macro appears to be cutting off a few lines and the bottom of our mail merged letter and the footer when the job prints in MS Word 2010. Do you have any ideas why?
        lhoyt@ikon.com
        With Selection.Find
        .Forward = True
        .Wrap = False
        .Format = False
        .MatchCase = False
        End With
        Do
        Selection.Extend
        Loop
        End Sub
        position.
        • TheOwl
          • Nov 2008
          • 1732
          Re: Bizhub C203/FS519 - Mailmerge-stapling
          Try this one. I have been giving this to customers to use for years. It is for older versions of Word, but the pricipal should be the same.
          Mail Merge.pdf
