Di2510f error C-500
  • Will
    • Jun 2007
    • 171
    Di2510f error C-500
    Just replaced upper fuser roller and put back together
    and keep getting C-500 error low fuser temperature. Checked all
    connections and reads continuity across both heater lamps, and thermostat and infinity across both thermistors. Do a trouble reset
    and C-500 just keeps coming back. Can see that the heater lamps never come on. Don't understand what happened, was working just fine before roller changed, is there something I'm overlooking or can do. Need suggestions
  • mjunkaged
    • 384
    Did you answer your own question, or??
    So, both thermistors are cut or blown. They shouldn't normally read infinity=open!!!!!
    Yes?
    • mjunkaged
      • 384
      other things....
      Did you check for continuity at the 2 pin plug for the lamps?
      If you still get no lamps after making sure the thermistors DON'T read infinity, you may have a blown fuse on the PWB-A, or a blown board.
      It's behind the entire mfb cage and tough to get in and out!
      Better hope it IS the thermistors, much quicker/easier!
      • Will
        • Jun 2007
        • 171
        Di2510f C-500 error
        Yes checked continuity at connector for lamps and are fine. What resistance are the thermisters suppose to read the book says should read infinety. Actually I think they read in mega ohm area, but will double check that.
        Thanks for the info on the fuse for board A will check that too. Can you tell me what kind of fuse it is?
