fiery server - new hard drive
  • howertoneng
    • May 2025
    I have a fiery x3e server running on my Konica printer, that is routinely locking up. I want to replace the hard drive. Anyone with tips on doing this, since i have never done this. Where can i download the server software?
    thanks
  • rasman67
    If you are not a tech then I would suggest finding one in your area to do the job for you. good luck
    • howertoneng
      I am confident in my technical abilities, just need some guidance.
      • Jules Winfield
        • Jul 2009
        • 821
        No, seriously. You'll need to involve a certified dealer in order to get the system software and instructions needed to install on the new HDD.
        But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
        • random
          There is probably half a dozen different versions of X3e so you need tell us what machine it is for a start, even then, and I have had to do it, there no garantee of succses. We just ghost them now, too much hassle.
          • howertoneng
            konica minolta
            OK, so i can do a ghost image of the hard drive, then load onto a new hard driver, and that will usually work?
            • Hansoon
              • Sep 2007
              • 3347
              XXCLONE works very well for this. Use it very often.
              XXCLONE, A New Way of Cloning the Windows System Disk
              Hans
              “ Sent from my Intel 80286 using MS-DOS 2.0
              https://www.copytechnet.com/images/smilies/biggrin.png
              • random
                Take the drive out and do a disk check on it, that will tell you if the drive is a dud or not. If you decide to ghost it you need to be aware that it is more than likely a Linux version and you will need to use special command line switchs. Others should be able to help you with this.
                • gqtrebor
                  • Aug 2009
                  • 10
                  Yes and you can use a bigger size hdd to. it works.
