bizhub 350, turn off scan confirmation page
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    After I installed the fax kit in this and set it to print a confirmation page for every fax sent, she called back and said that it was printing one for every page scanned also. Is there a soft switch setting to separate the two?
  • mascan42
    • Oct 2008
    • 484
    Turn soft switch 368 bit 1 to 0.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      Thanks for the reply but the new bizhubs are a little different. When you go to soft switch settings, you enter a 3 digit number for MODE, then it will pull up an 8 digit string with the "1's and 0's" you flip those to make changes. I will have to find the mode and then which bit to change.
      • mascan42
        • Oct 2008
        • 484
        Mode 368, bit 1. Switch it to 0.
        It should read 11000000 when you're done.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Sorry for the confusion. I thought maybe you saying mode but when I used that I must of looked at the string backwards or something and I just wanted to clarify. Thanks again for your input.
