compatibility of fax kit from BH200 to BH350
  • spektrumdx7
    • Jun 2025
    I'm wanting to transfer a fax kit from a bizhub BH200 to a BH350. First of all, is it compatible? If so, if anyone knows the procedure it would very helpful. I found the fax board behind the back panel. I'm sure there's at least one DIMM chip to move, anything else. Also, do I need to activate the fax in service mode after install and if so how to go into service mode. Thanks. First time working on a bizhub so thanks for any help.
  • Hansoon
    • Sep 2007
    • 3374
    Kits are the same for the BH-200, 250, 350 series. Consisting of Fax board, Hookup Harness, Backup Battery and an additional chip located at position CN5 (nearest the firmware update port.)
    Here is the installation guide:
    YouSendIt - Send large files - transfer delivery - FTP Replacement
    Hans
