c200 help abortc code 00100100
  • copiers4africa
    • Jul 2009
    • 47
    has any one had this problem.....we added extra memeory to this machine and 2 days later this code comes up.. remove the extra meemory and reset machine problem still the same..
    any ideas pls help
  • mascan42
    • Oct 2008
    • 485
    The most likely cause is either the remaining memory chip or the MFB board. If the machine also has a fax unit, that could also be the issue.
    • copiers4africa
      • Jul 2009
      • 47
      thank u ..will try on monday
      thnx will try monday
