Hello!
I bought a refurbished Konica 7045 machines, there is no Company carrying this model here, and the company that does carry Konica only has Konica 7033 and you cant buy parts from them unless you bought the machine from them, which i didnt.
Now the problem is, when it was time to replace the drum, i bought a "compatible" drum, developer and cleaning blade. I calibrated after installation as instructed by the Supplier's tech via phone, since im located across the sea from my supplier. When i test print, the copies were very light.
I dont have a tech nearby who knows the machine so i have to live with the phone tech instructions. He got me to print the adjustment list, i corrected everything from the HV adjustment list, except for Dmax LED, and L detection, since he said you cant set it to default once you calibrated the new drum and developer. I also did Toner Auto Supply and still no improvement. My copies are light, clean but very light, its gray.
Is there any other way to solve this problem?
My old drum had really good copies but since there were already marks on the copies so it had to be replaced.
