CF-3102 Access Problem
+ More Options
Posts
  • captain1976
    • Jul 2008
    • 79
    I just got a nice machine from a wholesaler but when I turn it on it just says;
    "Please enter your 4 digit access number"
    Anyone know how to get rid of it? I went into the service mode but thats all I can do.
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Copy track is enabled on the machine.
    Disable it through administrator.
    Tap the utility key and then press "admin mode" on the screen.
    Password is default 0000
    This should allow you into the mode (if it does not, let us know)
    Touch "copy track"
    Touch "copy track mode" and touch "no" and touch enter and back out of admin mode. You may be prompted with a warning about clearing data, select yes to clear it. Once you are done, copy track should be disabled and you can use the machine normally.
    You can download the user and admin manuals for this machine from KonicaMinolta.ca or konicaminolta.com
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • captain1976
      • Jul 2008
      • 79
      Hi,
      I went through it but it still wants that 4 digit code, obviously what the old owner put it. Still no able to use. Any other suggestions?
      • captain1976
        • Jul 2008
        • 79
        Let me clarify. I did get into the copy track mode and followed the procedure as you mentioned, but still nothing.
        Can't find it in the manual but can look again
        • captain1976
          • Jul 2008
          • 79
          Touch "copy track"
          Guess what? I did it a couple more times and it cleared.
          Thanks very much for your help
