Thanks Big Jase,
that was M charger unit problem,replaced and rectified
Sometimes, the connector in the front can become intermittent from the constant PM cycles where we have to remove the dev unit. I've had to "rewire" the plug a couple times on one machine (different dev units). One of the wires breaks inside the insulating plastic from the wiggling of this connector as its pushed and pulled. Easy to fix and easy to diagnose. Simply give each wire strand a light pull in line with the wire to connector. If the insulation stretches, there is a break. If not, the wire is ok. I habitually check this every time I do a dev restart or replace the dev.
"Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
