minolta EP 3050
  • m_e_s_group
    minolta EP 3050
    plz help me in this problem
    the copier gives me the symbol of maintenance .(the key )
  • Scott_Lewis
    • Mar 2007
    • 519
    Are you talking about the little wrench in the lower left corner of the LCD screen?
    If so, touch the wrench. You will be taken to a screen with a list of fail codes. You may be able to reset the codes and disabled components by opening and closing the front cover while that screen is displayed.
    • tashima
      Tashima
      • Apr 2007
      • 10
      check te code
      look at the codes in the troubles menu by pressing stop 0 stop 1 and choosing the sub menu at your convenience, if you can see for example in the key wrench at the display an E00400 look in the menu what it menas
