C350 colour issues
  • OutlawTorn
    • Aug 2008
    • 189
    C350 colour issues
    Hey all,
    I am having trouble getting a C350's image back up to scratch. The cyan is extremely dark and is bleeding for some reason. The machine has recently had a new fusing unit and transfer belt.
    I have had this problem before with image fogging and cleaning the LED bank underneath the imaging units and resetting/recalibrating has always fixed it - not this time though.
    any ideas?
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Check to see if your background voltage, D Max Density, Transfer Output, bias have been set outside of standard in tech rep. Also, check to see if cyan TCR Level Setting has been adjusted, or move it down a couple notches if it hasn't.
    Do another reset and stabilize. after that, print out a dozen or so 11x17 halftones of cyan. Then another reset and stabilize, gradation adjust 3 times, and then turn dev bias choice on. This latter will disable gradation adjustment just in case you are not aware. play the wait and see.
    Failing that, try a used cyan IU in place. If it corrects itself, then you have a bad dev unit.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • Cantechman
      • Nov 2008
      • 228
      The LED assy itself has given me issues on this model in the past. You can switch LEDs to see if the issue follows it. Its a pain to do it though I know.
