Konica Bizhub c250 Screen Problem
  • martin_dalton
    • Sep 2025
    Hi
    I dont Know if anyone has come across this problem and could help me, but im having a problem with the back light on a c250 control panel.
    I can still see the screen and all the buttons but i have now back light, i have done the usual "trouble reset" but that hasnt helped. Below is a number of boards i have also replaced
    -complete new control panel
    -new pcb-sif board
    -swopped a power board with another machine
    -swopped a pcb-c image processing board with another machine
    -done a firmware upgrade - but not nvram recovery
    The only board i havent replaced is the main board, which im abit reluctant to do just yet. Has anyone had this problem with this machine? as im slowly pulling all my hair out.
    I probably know what the answer will be "replace the mfp board" but i was just hoping someone has had the problem and could give me a solution without doing the mfp board
    regards
    tom
  • RRodgers
    • Jun 2009
    • 1947
    Maybe bad inverter on the back light.
    • martin_dalton
      it has already had a new control panel which worked on another machine
      • Leandro Bourne
        Re: Konica Bizhub c250 Screen Problem
        Do you Solve the problem?
        i have two machine with this same problem =/
        • mdtrinh
          • Aug 2010
          • 68
          Hi
          -new pcb-sif board
          regards
          tom
          Try to replace the PWB-M board, next to power supply, close to right rear of the machine.
          It work for me!!!
          Good luck!
          • hazartilirot
            • Aug 2016
            • 10
            Wow! It has lasted for more than six years... Can I ask you as to how you solved the problem? Your problem sounds as mine. I've already changed: Control Panel, Mechanical Control Board and Power Unit - still no luck.
