Bizhub C350 and SMP Scanning
  • Coredump
    I have been reading everything I can, and it has not quite added up.
    I have a Bizhub C350, which I would like to be able to Scan to PC.
    I have connected to the 350 via browser, and tried to set up a one touch key. 2 problems:
    1) I have 3 sets of 'boxes' to click on. I know I need to click on the 3 dashes near the bottom, but do I want
    Storage>Storage1> ---
    or
    Scan>Scan1> ---
    2) In either case, I get to select Scan to PC, and then asked to give a Destination Name and IP address.
    It never asks me for a destination folder, or password, or anything like that.
  • buster68
    • Nov 2008
    • 181
    the C350 is not SMB compatible. You'll need to run an FTP service on your computer. Then on the administrator portion of the copiers web connection, you'll set up the FTP destination with the FTP service information...ip address, destination folder etc. Then you can set up a one touch and select one of the FTP destinations. If you're copier is equipped with the optional Harddisk Drive, you can scan to that as well and use the Box Utility program to retrieve scans from the copier.
