cf9001 Problems again
  • BUSHWACKER
    • Aug 2008
    • 25
    Greetings all the cf9001 driving me dilly
    Fan faulty as was correctly diagnosed by you kind folk.
    I have however just powered the monster up th check a different fan
    screen comes up with a message:
    engine downloading completed
    check sum
    I.R.
    N.G. HELP BEFORE I GO NUTS
    THANX
    BUSHWACKER
  • BUSHWACKER
    • Aug 2008
    • 25
    check sum
    I.R.
    THANX
    BUSHWACKER
    Well well I never thought I would see the day that I stumped the team.
    No one in this neck of the woods is able to help either.
    • mrwho
      Major Asshole!
      • 4299
      Did you by any chance forget to remove the firmware card from the machine's board?
      Mascan42
      Ibid
      • BUSHWACKER
        • Aug 2008
        • 25
        firmware card
        No did not do anything related to firmware card, the machine was switched on and this message comes up on top of the normal info that is being displayed i.e error re fiery 24 volt fan which is unobtainable in South Africa
        Regards
        Bushwacker
        • mrwho
          Major Asshole!
          • 4299
          So that error is related to the machine or to the Fiery?
          Usually that kind of message pops up when finishing a firmware update on the machine. If it's Fiery related, then I can't see a connection.
          Mascan42
          Ibid
          • BUSHWACKER
            • Aug 2008
            • 25
            firmware
            No firmware update has been done, no card in the machine
            The firmware update type message is appearing, but for no apparent reason.
            The fiery problem re the fan is a seperate issue.
            Regards
            Brian ( Bushwacker)
            • mrwho
              Major Asshole!
              • 4299
              Well, if that is so my guess is you have some kind of board problem.
              If you can, try to reflash the machine's firmware. Also, check the boards for any bent pins and reseat all the connectors.
              I can't think of anything else, sorry. Searched my docs and couldn't find anything like that.
              Mascan42
              Ibid
              • kalindd
                • Jun 2008
                • 192
                I've seen this in the past.
                As far as I remember the problem was fixed with reseating one of the eprom's on the machine pwb. the one top of the fiery.
                Or you need to flash the firmware.
                I hope this helps.
                • Stirton.M
                  All things Konica Minolta
                  • Oct 2009
                  • 1804
                  I went through what I had as well and found nothing.
                  This could have some to do with what I predicted earlier regarding this particular machine and the removal of the Fiery controller because of the bad fan. I suspected it would interfere with the inner workings of the machine if removed, but I wasn't sure because quite frankly, I've never worked on one without the fiery installed. There could be a correlation between the two.
                  "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                  ---Groucho Marx
                  Please do not PM me for questions related to Konica Minolta hardware.
                  I will not answer requests or questions there.
                  Please ask in the KM forum for the benefit of others to see the question and give their input.
                  • Luong Nam
                    • Oct 2009
                    • 49
                    Konica Minolta CF9001 SM
                    Go: Exchange Service Manual
                    Get free link at here
                    • cyber61
                      Re: cf9001 Problems again
                      I have the same problem.
                      check sum
                      I.R.
                      N.G.
                      did you solve it?
                      I got the problem after the power plug was unplugged for a while (2 days)
                      Fiery is working and I get a connection but the hardware does not work.
                      ...please HEEEELP.
                      THX a lot
                      • cyber61
                        check sum
                        I.R.
                        N.G.
                        did you solve it?
                        ...please HEEEELP.
                        THX a lot
                        • kniezarastislav
                          Hello friend,
                          do you have a service manual for cf9001 please? Would help very much. My printer does not start at all. THX.
                          • JustManuals
                            • Jan 2006
                            • 9838
                            Paul@justmanuals.com
                            • cyber61
                              Originally posted by kniezarastislav
                              Hello friend,
