tengo un problema en el sistema de recicleo de toner, se satura de toner y lo empieza a tirar, si alguien sabe como solucinarlo se los agradeceria gracias saludos
konica minolta 7272
Tags: 7272, amou, cleaning blade, fondo, konica, konicaminolta, lef, limits, maintenance kit, mejor, minolta
amounting-spilling toner konica 7272
i have problem with to konica 7272, spill toner and amount in the recyclen sistem, thanks for your helpComment
Try this...
The problem as stated in Spanish is the toner pilling up in the recycling section (underneath cleaning blade) and not circulating and then spilling over.
I would check the clutch in the rear of that section on the drum carriage Make sure it is plugged in, the wires for it not pinched and manually move the gears on that clutch to make sure the augers are moving. Also, thoroughly clean out (vacuum) the recycling section and pipe. You might also want to change the toner guide roller - if it is old and the foam loose, it might interfere with the recycling augers.
Suerte.
Si no entiende algo que mentione, mandeme un mensaje privado y tratare de alludarle. Mi castellano no es de lo mejor.Comment
