di550 error c133b
  • mkdi550
    • Aug 2025
    di550 error c133b
    I was disconnecting the finisher while the copier was powered on and I got an error code c133b. I turned the copier off, reconnected the finisher, turned it back on and still get this error message. Can anyone help me with clearing it?
  • albasoul06
    The copier displays error code C-133B.
    CAUSE: This code is displayed when there is a communication problem between the copier and the finisher.
    SOLUTION: Please check all connections and inspect the interface harness. The firmware of the copier has been updated to correct the false indication of C-133B codes.
    • mkdi550
      I've reconnected the finisher, checked the interface and everything looks fine, but I'm still getting the error code.
      • minimerlin
        • 851
        Have you tried to reset by cycling the front door and/or trouble reset switch?
        Please do not PM me without asking first.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          I think I did the same thing once. I believe you have smoked the board on the finisher.
