Di470 Finisher part number
  • OBXtech
    \tek-หˆni-shษ™n\
    • Sep 2009
    • 37
    I'm looking for an accurate part number for the pin that attaches to the Di470 main body that a FN-105 finisher slides onto.
    The part number that I have is 4643U007AA. I got this part number from the first page of the installation guide where all included parts are listed. The part number comes back as invalid. I cannot find the part number anywhere in the FN-105 parts guide.
    We've had these pins break before in the past, so I'm assuming that someone out there has replaced one before. Thanks for your help!
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
  • BR549
    • 111
    The pin only is 4643-2109-01, the plate the pin mounts to is 4643-2108-01, the spring behind the plate is 4643-2110-01.
    • albasoul06
      i hope this help
      Parts manual attached
      Originally posted by obxtech
      i'm looking for an accurate part number for the pin that attaches to the di470 main body that a fn-105 finisher slides onto.
      The part number that i have is 4643u007aa. I got this part number from the first page of the installation guide where all included parts are listed. The part number comes back as invalid. I cannot find the part number anywhere in the fn-105 parts guide.
      We've had these pins break before in the past, so i'm assuming that someone out there has replaced one before. Thanks for your help!
      • albasoul06
        parts manual
        OK ?
        • wagon
          Village Idiot
          • Dec 2006
          • 654
          Usually, with care, you can remove the broken screw from the pin and replace it. Have you tried that?
          If you are hitting your head up against a wall it always feels better when you stop.
