Biz Hub C450, No magenta color
  • newtechbiz
    Hi, I have c450 now and there is no error message or no replace iu message, suddenly comes out magenta color is very lighter. please help.
  • RRodgers
    • Jun 2009
    • 1947
    Take it out and shake the crap out of it. (try not to let the toner spill out) I've seen a lot of C450 Magenta IU's go bad. Usually you just replace them and then they work fine. "sometimes" (and I mean rarely) shaking them will bring them back.
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      The key here is suddenly, try another Transfer Belt most any thing else would be gradual or give a code.
      Now into Ip TV KODI Boxes
      • newtechbiz
        C450 magenta color
        Thanks for your advised and I tried shaked iu but it is the same.
        I think replacing the iu would be better.
        • newtechbiz
          C450 magenta color
          I think the color was lighter slowly.
          Because I compared the quality between 1st copy and last copy(total 500copies)
          • RRodgers
            • Jun 2009
            • 1947
            dup post... plz delete me
            • JtheCopyGuy
              • Aug 2009
              • 26
              I would replace the IU first and test the machine out. I've had a string of bad IU's that we THINK got sat on their side in transport, after a few hundred copies the back 2 inches of the IU gets very light.
              If it becomes a recurring issue it could be perhaps a power/charge issue?
              • mabawser
                Tech
                • Sep 2009
                • 121
                I'd recommend replacing the IU. I used to work for Konicaminolta up until last year and we had a mod for IU goin faint.
                It had to do with putting foam pads where the toner goes from the hopper into the IU. this seemed to help on problem machines. (just to say I havent got that write up for it though, sorry)
