Bizhub c450 error C6102: Drive Home Sensor malfunction
  • Guard
    • May 2025
    I plan to buy old C450. At the begining, I'd like to use it as a printer. The scaner belt is broken so the c6102 error occurs. Is the c450 able to work as a printer inspite of the c6102 error?
    Thank you!
  • albasoul06
    answer is N O
    and you may want to take a look on service manual page 113
    • Guard
      Don't you think it is possible to reset error status via service menu to make printer work?
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
        from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • minimerlin
          • 851
          Each time you switch on the machine you will get the code as it tries to check its functions and calibrate the scanner, even if you only want to use it as a printer. Why not fix the belt?
          Please do not PM me without asking first.
