Di350 Blank Copies
  • Solotime
    • 223
    Di350 Blank Copies
    OK this is weird. The copier will print the test page from the user screen just fine. But if you try and copy either thru the ADF or from the glass you get blank copies. So apparently must be something in the scanner?
    Hoping someone has seen this before as the service call is a bit of a trip for me.
  • OBXtech
    \tek-ˈni-shən\
    • Sep 2009
    • 37
    No error code? My first thought was exposure lamp, but it takes a white reference and will code out if the reference fails. The only other thoughts I have would be to check all the physical connections in the scanner. Make sure there are no wire breaks. However, I would assume that these would also cause an error code. Good luck!
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
    • mjunkaged
      • 383
      Check fiber optic cables!
      I believe if mem. serves me correctly it may be the fiber optic cables that lead from scanner to main pwb. If not then probably Inverter, BCR, first check cable HGB to main(fiber optic cable) It shouldn't be damaged, and should never be bent beyond about 45degrees.
      • eg101
        • Jan 2005
        • 131
        Probably the BCR board, behind the CCD.
