konica 7145 code F26XX
  • CHACHA
    • Jun 2025
    can you help me for this code F2603 the copier is konica 7145 ???
    thanks
  • albasoul06
    F26-03 displayed at power up and unable to perform L-detect.
    CAUSE: Worn developer.
    SOLUTION: Replace the developer (PCUA 960421).
    F26-03, and the developer spilling
    CAUSE: The TDS (toner density sensor) wiring has been pinched and is shorted to frame ground.
    SOLUTION: Replace the TDS sensor (p/n 26NA88040).
    F26-03, after replacing the developer
    CAUSE: The reading from TDS (toner density sensor) is incorrect.
    SOLUTION: Clean the TDS sensor (p/n 26NA88040), and run L detect.
    • CHACHA
      thanks for this information;
