konica 7033 no lcd display
  • mdm7266
    • Dec 2007
    • 99
    hello there! my problem with this konica 7033 is when i turn the power on, the control panel/lcd has no display. only the green data LED on the panel lights up. i removed the platen glass and remove the cover on the board, the 2 led lights up. could this be a board problem? the board on top of the laser/write unit assy?
    I read this technical information:
    Solution ID
    TAUS0610291EN* Solution Usage 36
    Description
    No power. Display is blank with only the green data light ON.
    Solution
    PROBABLE CAUSES:
    1. System firmware is corrupt; possibly due to a sudden loss or surge of AC power supplied to the copier.
    Flash both the system and image firmware. If the 7040 will not allow access to 25 mode, perform the following:
    a. Power the copier OFF (SW2 [operation panel] first, then SW1 [left rear]).
    b. Prepare the laptop PC or the ICW TOOL for flashing and connect it normally to the 7040.
    c. Power the copier ON (SW1 [left rear]) first, then SW2 [operation panel]).
    d. Send the system firmware from the laptop PC or the ICW TOOL to the 7040. The green data light will begin blinking.
    e. The LCD display will reappear, in the normal ISW flash mode screen, when the system firmware has completed its flash.
    f. Flash the image firmware.
    Notes:
    1. For procedures on how to flash the firmware, refer to 7040/7033 [Technical Bulletin #7]. Currently main CB system firmware is at level 37 and Image
    firmware is at level 25.
    2. It is highly recommended that all 7040's and 7033's be plugged into a power tamer device (p/n 11515C) for added protection.
    2. Failed main CB. A sudden loss or surge of AC power supplied to the copier may have caused the main CB failure.
    Replace the main CB (p/n 55GA-9300).
    Notes:
    a. It may be necessary to flash the copier firmware because of the possibility that the replacement main CB may not have the correct system firmware level
    to match the level of the image firmware on the Image Processing board. For procedures on how to flash the firmware, refer to 7040/7033 [Technical Bulletin
    #7]. Currently main CB system firmware is at level 37 and Image firmware is at level 25.
    b. It is highly recommended that all 7040's and 7033's be plugged into a power tamer device (p/n 11515C) for added protection.
    Can anybody help me, can provide me the necessary software/firmware to flash this unit?
  • barratec
    • Jun 2008
    • 162
    maybe you have to reinstall the firmware.
    • barratec
      • Jun 2008
      • 162
      I attached the system (v.45) and image (v.26) firmware to write via parallel cable and ISWtrns utility.
      If you need this utility too send me a email address.
      • mdm7266
        • Dec 2007
        • 99
        email address
        my email: mdm7266@yahoo.com
        thanks
        • Hansoon
          • Sep 2007
          • 3389
          Could I please have a copy of this ISWtrns utility too?
          New customer just called and described exactly the same problem after a sudden power cut. I have never seen this machine before (doing mainly Minolta's) so I could use any hints or help in this case. Many thanks in advance.
          nospam@rex-technika.com
          Hans
          • mdm7266
            • Dec 2007
            • 99
            thank you very much barratec for your ISWtrns utility / firmware.
            i already flash/update the konica 7033. It is now working as it is.
            Again thank you......
            • Hansoon
              • Sep 2007
              • 3389
              Would anybody kindly share this utility with me?
              nospam@rex-technica.com
              Hans
              • mdm7266
                • Dec 2007
                • 99
                konica 7033 iswtrns
                hello hansoon,
                maybe you could ask barratec for the ISWtrns utility.
                i have it but i dont know how to attach it for you to download it.
                • Hansoon
                  • Sep 2007
                  • 3389
                  Originally posted by mdm7266
                  hello hansoon,
                  Hi, just forwarding that incoming mail perhaps?
                  Hans
                  • barratec
                    • Jun 2008
                    • 162
                    Your welcome mdm7266!
                    • barratec
                      • Jun 2008
                      • 162
                      Hans
                      Hi hanson! I've just send to you by mail the utility that you need.
                      • Hansoon
                        • Sep 2007
                        • 3389
                        Hello Barratec,
                        thanks for your efforts, very kind. It didn't came yet so herewith once again the e-mail address:
                        Hansoon
                        • barratec
                          • Jun 2008
                          • 162
                          Hello Barratec,
                          Hansoon
                          Hello, i've tried again to send to you the utility, i'll be more lucky???
                          • Hansoon
                            • Sep 2007
                            • 3389
                            No unfortunately not. Would you kindly try alternative:
                            hans@rex-technika.com ?
                            Many thanks
                            Hansoon
                            • mdm7266
                              • Dec 2007
                              • 99
                              iswtrns
                              Hans
                              send me your email
