Di 551 / 650
  • shark66
    • Nov 2009
    • 6
    Di 551 / 650
    Minolta DI 551
    Code SC 49-01 ??
    thanks
  • mrwho
    Major Asshole!
    • 4299
    DESCRIPTION: Intermittent SC49-01.
    CAUSE: Failed printer control board assembly.
    SOLUTION: Ensure that the system code on the IP511 is at minimum version 6.2.0. Remove the IP511 from the main body and inspect the connection to the main body for any damage or pins out of place.
    Reseat the IP511 onto the main body and verify operation. If the service code continues to occur, replace the printer control board assembly (p/n 13RN-7320).
    Mascan42
    Ibid
    • shark66
      • Nov 2009
      • 6
      THANKS
      • TonerMonkey
        • Jun 2005
        • 71
        Don't forget to reload controller firmware first before replacing anything (which in most cases will work).
        • bely
          I have service manual if you need it.
          • shark66
            • Nov 2009
            • 6
            bely sm would be great.
            info.blueprint@googlemail.com
            • bely
              chek your mail
              • killersilver
                I need the manual too please
                Hello.
                I run a PC Technical Support Business and yesterday i was called to install a Pi6500e controller to a Minolta Di551 and i had no idea what to do at first because i have never dealt with copier machines before.
                After doing some basic things i was caught with a SC56-04 error code when trying to print the configuration page with the controller plugged in.
                I was reading there could be 2 problems:
                - Physical and electronic serials not matching.
                The solution was supposed to be entering 25 mode and changing the serials there, but only the main body, option tray and finisher were available, not the controller.
                - Updating the firmware to allow the controller to be recognized.
                Here, i don't have a clue where to start from. They didn't even provide me the cd/manual. I read that bely had it. Can you please be so kind to send it to me? killersilver [at] gmail [dot] com.
                Thank you very much in advance.
                • Morlock49
                  • Mar 2009
                  • 166
                  C49-01 is also caused by the operator switching off the copier and not shutting down the print controller before hand.
                  what happens is the print controller loses sync with the copier.
                  so before going too technical, goto the machine and shut down the controller, then switch off the copier on the rear on/off switch. leave for about 30 secs and then switch on the copier. I hope this helps.
                  Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
                  • Luong Nam
                    • Oct 2009
                    • 49
                    Konica Minolta Di-551_650
                    Go : Exchange Service Manual
                    Get your option service manual with free link
