I just bought a Bizhub C351. I went in and programed the IP address, gateway etc.. I turned that machine off as instructed and turned on as instructed, however when I I go to my desktop and put in the IP address it does not alow me to bring up pagescope. It says http error 400. I went into my dos window and "ping" the ip address and that works shwoing it exist. Any idea of what not working? I also went in and let it auto sign an ip address and tried accessing it and that did not work either.
Can not access Pagescope
Three possible things to look at here.
1. Unplug the copier from the network and then try pinging the machine again just to make sure that the IP address isn't used by something else.
2. Try plugging a PC or Laptop directly into the copier and try the web interface.
3. As suggested in another post, try Firefox. With these machines and the release of .Netframe Work 3, IE will have issues talking correctly to the printer. A firmware upgrade will fix this issues if you find that Firefox works.Please don't ask me for firmware or service manuals as refusal often offends.Comment
3. As suggested in another post, try Firefox. With these machines and the release of .Netframe Work 3, IE will have issues talking correctly to the printer. A firmware upgrade will fix this issues if you find that Firefox works.Comment
CFP
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
In this case, you would need to do a firmware upgrade on the machine.
When .Net FrameWork 3 came out, it stopped IE from communicating properly with the machines. Konica Minolta saw this as a fault with the machines and released firmware to fix the issue.Please don't ask me for firmware or service manuals as refusal often offends.Comment
