Minolta Di3510 Adobe printing
  • fishman911
    • Aug 2025
    I have one customer when printing adobe files the file seem to take a very long time to load onto the copier before printing.
    All other printing seems ok
    Is there some setting on the copier that expediates these kinds of files
    They are not large files they emailed them to me and i printed them on my own small copier fairly quick
  • TheOwl
    • Nov 2008
    • 1732
    Does your customer have the Postscript kit installed on the copier? If so, are they using the PCL or PS driver?
    If they are using the PCL driver, then the print data has to be converted from PS to PCL in the print spool before the data is then sent to the copier. Doing this can make some small files rather big and could explain why it is taking some time for the document to get to the printer.
    • nmfaxman
      • 1702
      Have them go to properties of the print driver and select PRINT AS IMAGE.
      Different algorithm and won't search for a PS font.
      It will print text as a picture.
      • nmfaxman
        • 1702
        Correction
        Select the document properties when they print the document.
        My mistake.
        • kmcopier
          PSP
          • Oct 2008
          • 183
          Did you installed HDD? did you also installed extra memory? Then try disable HDD! if solved increase memory !
