Konic 7022 F-46-8
  • Comrep
    • 22
    Konic 7022 F-46-8
    I am working on a Konica 7022 that had a F35-3 error code. I reset it in SW switch 3-1:1 I now get a F-46-8 error. Can anyone tell me what it is and how to reset it? Thanks. Scott
    Build it idiot proof and the village builds a better idiot
  • CMB
    KonicaMinolta Tech.
    • Mar 2005
    • 457
    replace the thermistors and then reset it.
    • Comrep
      • 22
      Hi CMB, I had posted on Smarka also on this issue. A tech there says that it is the laser unit. Does the book tell you that this is what the error code means or is it experience that tells you this? Thanks. Scott
      • CMB
        KonicaMinolta Tech.
        • Mar 2005
        • 457
        sorry i gave you the wrong info the first time.....
        Solution ID
        TAUS0619168EN00 Solution Usage 37
        Description
        F46-8 at power up.
        Solution
        CAUSE: Laser index error caused by a failed index sensor board.
        SOLUTION: Replace write unit (p/n 26WA-6500).
        • Comrep
          • 22
          CMB Thanks for your help. I hope I can return the favor in the future. Scott
