Minolta Di 850
  • tmbentley
    Minolta Di 850
    I get uploading errors when the scan to email function is used. We scan to email to ourselves with-in our network (hard copy to ecopy). Our process: Set up = scan
    select = destination
    select pdf or tiff = tiff
    density =200 dpi
    scan to email 3 - 20 pages
    We do the same process as fast as the documents can fly through the ADF and add the next set and press start... the same address, just another set of documents.
    We get the uploading error at random times and machine will not accept the next scan to email. It sometimes frees up by itself and sometimes we have to turn the machine OFF and ON to clear the cashe or error.
    max scan file = (KB)15000 noted on Config sheet
    Important information, each page might be a 45 kb file..I knew you were thinking that was the problem..
    Our mailbox does not have a size limit so that's not the issue either.
    I don't think the email is even leaving the building its just hitting my server.
    Anyone else heard or seen this issue?
