Bizhub C500, Print without Fiery?
  • Glendini
    • Aug 2025
    Hi,
    I got a Bizhub Pro C500, there does not seem to be a fiery or any other print controller in it or with it.
    Do I need a Fiery or similar to be able to print from a pc or mac or is this just a photocopier without it?
    If I can, what drivers do I download?
    Thanks in advance,
    Nate
  • robizhub
    • Sep 2008
    • 36
    Yep you need fiery!
    • seeb
      • Nov 2009
      • 41
      Either a Fiery S450 rip or a Creo powerpro 500 would work.
      • RRodgers
        • Jun 2009
        • 1947
        Ya need a print controller to print.
        • brian155
          • Jan 2008
          • 50
          are you sure there is not an internal IP921 installed? how many network conections are on the side of the engine? dose anything change when you press the Print hard key?
          • Glendini
            Thanks MUCH!!
            Hey guys,
            Thanks so much for the help. I went and got a new Fiery for it, all works well.
            Thanks again ;-)
            Nate
