Konica 7272 sc 23-04
  • Naveed Shahid
    • May 2008
    • 162
    Hello Every One
    I am facing a problem sc 23-04 i changed already pcl but cant solve problem can any one have a idea
    thanks in advance
  • leo
    • Jun 2008
    • 64
    Measure the ICP(small black IC)fuses on printercontrol-board
    i belive one of them are faulty. just soldier an normal glass fuse over the ICP
    check the servicemanual for the current
    • Naveed Shahid
      • May 2008
      • 162
      helo leo
      dear leo
      i already open th printer control board but i can't found icp or fuses co can u give a fever confirm me ic name or fuse name i reaaly appciate u
      thanks
      • leo
        • Jun 2008
        • 64
        you can find 3 of them in lower right corner(see att. picture) as an example.
        there is a lot of them over the whole card.
        PCL is connected to with connector 206 on top of the card, pin 17 and 18, so you can follow the "print-lines" if you have eyes.
        • Naveed Shahid
          • May 2008
          • 162
          konica 7272 23-04
          thanks for great support i will fininshed problem soon
          thanks once again
          • chand
            • Oct 2007
            • 12
            Re: konica 7272 23-04
            thanks once again
            hi
            did you solve the problem???
            • leo
              • Jun 2008
              • 64
              Re: Konica 7272 sc 23-04
              Diego Silva, Great player
              • chand
                • Oct 2007
                • 12
                no problem of any board...i solve this problem easily..only hardware problem
                contact me chand226@gmail.com
                • chand
                  • Oct 2007
                  • 12
                  • rhalif
                    I have the same error sc 23-04 with dialta 5510, I tried to change the pcl but it didnt work, I checked also the 3 icp, they all look good, anyone can help me with this ?
