C450 Scanning
  • rasman67
    • Aug 2025
    C450 Scanning
    I have a customer with a C450 with the standard print controller the print and scan works great on his Macs. When I install a Fiery with Version 2.01 system software the print works fine but won't scan. If anyone has an answer i would appreciate it
    thanks in advanced
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Was apple talk enabled on the previous fiery system, along with scan? Check to make sure DNS is set as well as workgroups.
    Also, did you apply all relevant patches?
    also, from a tsb on the the ic 402,
    Solution ID
    TAUS0652106EN* Solution Usage 0
    Description
    SMB scanning compatibility with Macintosh*.
    Solution
    With the upgrade to version A7 on the C450/C351, scan to SMB in environments running Samba* is now possible. This would include later LINUX* versions
    and Macintosh OS X as well as any other UNIX* OS that has the Samba package loaded on it.
    Notes:
    1. Samba versions 2.0 and 3.0 are supported.
    2. SMB signatures are NOT supported.
    3. The parameters, workstation requirements, and limitations that are associated with Microsoft* Windows SMB scanning still apply.
    There is more, but let me know if these are not successful.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
