bizhub 210
  • gregoryk
    • Jul 2025
    bizhub 210
    hi friends.Does anyone can tell me if i must reset any counter after replacing the developer material? if yes, can you tell me the procedure?
  • jeroen2005
    • 48
    Hello,
    Service Mode function setting procedure
    NOTE
    • Care must be used to ensure that only the personnel who are involved in service
    jobs know the procedure to enter the Service mode.
    10.1.1 Procedure
    1.
    Press the Utility key.
    2.
    Press the following keys in this order.
    3.
    Stop 0 0 Stop 0 1
    4.
    The Service mode menu screen will appear.
    10.1.2 Exiting
    • Press the Panel Reset key as many times as it is required to display the initial screen.
    10.1.3 Changing the Setting Value in Service Mode Functions
    1.
    Select the desired item using [ / ] key.
    2.
    Select the setting value using [ / ] key, [ < / > ] key, or the 10-Key Pad.
    3.
    Validate the selection by pressing the [Yes] key.
    4. To go back to previous screen, press the [No] key.
    Go to 3 counters and reset maintaince and supplies.
    Then 5 do ATDC adjustment
    Jeroen2005
    • gregoryk
      thank's a lot i appreciated
